Dabar yra 24 Geg 2012, 07:48
Naujos temos kūrimas Atsakyti į temą  [ 5 pranešimai(ų) ]
 Pranešimo tema: 2007 ZX6R Specs
StandartinėParašytas: 11 Spa 2006, 21:40
Pranešimai: 8617
Engine Type Four-stroke, liquid-cooled, DOHC, four valves per cylinder, inline-four
Displacement 599 cc
Bore x Stroke 67.0 x 42.5mm
Maximum Torque TBD
Compression Ratio 13.9:1
Fuel Injection DFIĀ® with four 38mm Keihin throttle bodies, oval sub-throttles, two injectors per throttle body
Ignition TCBI with digital advance
Transmission 6-Speed
Final Drive X-Ring Chain
Rake/Trail TBD
Frame type Aluminum perimeter
Front Tire Size 120/65-ZR17
Rear Tire Size 180/55-ZR17
Wheelbase TBD
Front Suspension / wheel travel 41 mm inverted cartridge fork with top-out springs, stepless rebound damping, stepless compression damping, fully-adjustable spring preload / TBD
Rear Suspension / wheel travel Bottom-Link Uni-TrakĀ® with gas-charged shock, top-out spring and pillow ball upper mount, dual-range (high/low-speed) stepless compression damping, 25-way Adjustable rebound damping, fully-adjustable spring preload / TBD
Front Brake Type Dual 300mm petal-type rotors with four-piston, four-pad calipers
Rear Brake Type Single 210mm petal-type rotor with single-piston caliper
Fuel Tank Capacity 4.5 gal.
Seat Height TBD
Dry Weight TBD
Color Lime Green, Two-tone: Lime Green / Flat Stoic Black, Ebony, Passion Red
Warranty 12 months
Good Timesā„¢ Protection Plan 12, 24, 36 or 48 months
Pranešimai: 8617
13.9 suspaudimo laipsnis...normalei? :)
Ir su 95-tu benzu :D
StandartinėParašytas: 11 Spa 2006, 21:56
Užsiregistravo: 27 Bir 2006, 12:25
Pranešimai: 955
Miestas: sheshku ghetto
Diesel? :oops:
StandartinėParašytas: 11 Spa 2006, 22:33
Pranešimai: 8617
TDCHDI :chain:
StandartinėParašytas: 11 Spa 2006, 22:52
Pranešimai: 4147
Miestas: yes
jo suspaudimas!! #-o
dar idomi fishke: galinio amortiko virshutine atrama per rutulini guoliuka ar tiesiog per ball'a. cia kitu mocu jau tiuningo teritorija. kwako oem spec. ispudinga visuomet.
beje sportrideryje yra vienas kaip ir ilgalaikis projektas. ten bendradarbiauja su kazkokio raceriu-odinochka. tas ruoshe gonkem 6ninja. buvo reikalas pabert varikli, tai anas profesionaliai (?) komentuoja, kad jo nuomone kwakas daug neuzdirba ant situ modeliu: bais brangias technologijas ir medziagas rado varikly.
ir taip toliau.
