nukritai, uzhgeso per keleta sekundziu. tai paskui gali arba kikint 5 minutes ir tada tik uzhkikinsi, arba rukyt nieko nedarant ir po penkiu minuciu uzhsikikins laisvai.
o barmalejus turi dekompresoriaus rankenėlę?
Forumuose kalba apie variklio gesinimo mygtuko jungimą dekompresinant. Tik nepagaunu, ar teisinga tai daryti engine off padėty ar on? Bandžiau visaip - visaip blogai
There are two drills to starting a downed pig But, First if you crash...lay it down, fall over (that last one is all the time for me). Make sure you don't have GAS coming out of the air box. This is where most of the argument will come form.
Most will tell you to hold the decompression lever in, while holding the kill button and kicking the bike through 3~5 times, up to ten times to clear out the fuel. Then at times if it was a real good spill there is so much fuel in the cylinder this can still not work and you start all over again.
The Race way:
You pick yourself up off the ground in a daze wondering where the bike is. Find the bike and pick it up. Fight the pain and hope you are pointing the right way. You pull the throttle wide open and grab the front brake! This is important....it stops the throttle from moving while you kick the bike over. Find TDC and kick as hard as you can and go! I have had a few argue with this but, once it is done without the throttle moving it works!
The main thing to know is the bike has way to much fuel in the cylinder to start so, you need to add lot's of air to get the fuel to fire. If you kick the bike over slowly to clear the engine and the spark lights the fuel the bike is on fire! Starting the bike the Race way pulls everything into the cylinder not back firing into the air box.
Some of my good friends that I ride with didn't believe it and it did not work for them. But, once they got the front brake thing down it was almost every time one kick...two at the most....
Hold the throttle wide open, holding the front break.....find Top Dead Center and kick!
reiks pabandyt "the race way"
va cia kazkas, ko tau reiktu. Paantrinant kita mitu skleideja Kauno tata lileiki "XR'as butu idealus enduro mocas, jeigu pakeitus karba ir idejus starteri"
El Traxo wrote:na, turint nefloodinantį karbą ir starteris nereikalingas. Dabar, būna, labai pritrūksta
siap, benzo krana uzsuki kai kickini po virtimo? maciau padeda...tokiam pat raudonam xr..dar girdejau mita , kad tipo reik moca palenkti ant sono ar pan. , bet nespjau pabandyt..isigijau su el starteriu kikint nereik, bet kai akumas nusedes draugai stumti turi taigi combo geriausia..
o kas del dekompresoriaus, tai gali minkyt ji ispaudes kiek tik nori. nu vistiek nesikuria, kol nepraeina kokios 5 minutes. vienu zodziu, ar darysi ar nedarysi, kuriasi tik sudundejus kurantams.
anyway, tata lileikis sako kad turetu kurtis tik po 10 minuciu
skaitau cia seniai zinomos XR problemos, reikai kreiptis i atitinkamus xr-u forumus ir spresti problema ten nurodytais budais. dar galiu pastebeti, kad hondos nelaiko ir nuturi tokio ivairiapusio palaikymo kaip husaberg.org.
skaitau cia tuscias laiko gaisinismas kalbos apie degimus ir kranelius. geriau laika skirtumet deti graziu mergeliu nuotraukas cia, kaip tai daro visu dzuku briedzis...
Gal ir tuščias gaišinimas, o bet norėjau pasitikrinti MF know-how.
Šiandien bandžiau empiriniu būdu. Race-way - nesikikina. Tada dekompresija su x10 kikų, x3 normalūs kikai, dar x10 dekompresijos ir užsikūrė kai jaunamartė.
Taigi, užkikinimas po pagulėjimo teužemė 2-3 min
