reisinginiai tepalai
ponai kolegos, nuomones nesiskiria, skiriasi alyvos.
cia buvo klausta kokia klampa nusako, kad alyva reisingine?
klausimas is principo neteisingas, todel ir gaunasi diskusija.
mums iprastu atveju (ir yprastos alyvos, nors ant bakelio ir parasyta RACE) is tiesu reikia imti su kuo aukstesniu antruoju skaiciumi.
o bet taciau yra ir kitokiu alyvu, bet ju panaudojimas ne gatvei.
beje perkancius tik pagal klampa labai graziai maudo alyvistai iprudydami pramonine alyva, t.y. skirta naudoti "po stogu". klampa ta pati, ko kaina 1/2
jei pirkejas tiek teraukia, tai bb jis pajus ka nors ar uzsmaugs ta savo mota, kad jam reiketu reisingines.
va vis dar neturiu ka veikti, tai brausinu apie alyvas.
prasome, minetosmazos klampos alyva, kalbant apie true reisinga:
http://www.essexparts.com/newproducts.html#0W20
0W-20 Advanced Racing Development Project
Racing Engine Oil
Special formulation, racing only 4-stroke engine oil using Electrosyntec Technology.
Silkolene 0W-20 Advanced Development Project engine oil is an entirely new concept in competition lubrication. Racing engines lose power due to oil drag and friction. This maximum power 0W-20 is a unique low viscosity synthetic which cuts oil drag yet maintains a tough low-wear film on highly stressed components. Specially researched friction modifier chemistry depends upon Electrostatic Adhesion to attack friction at crucial points in valve and power train systems—two sources of hidden power giving that vital edge in acceleration and full throttle output.
TEST RESULTS: Dynamometer tests on 0W-20 Advanced Development Project racing engine oil have produced amazing results. The test machine was an 1100cc 4-cylinder race engine.
15W-50 racing engine oil Max power 127.9 BHP @ 9750 RPM
Max torque 75.8 ft-lbs @ 7300 RPM
5W-40 racing engine oil Max power 131.6 BHP @ 9750 RPM
Max torque 77.7 ft-lbs @ 7400 RPM
0W-20 Advanced Development Project Max power 134.4 BHP @ 9750 RPM
Max torque 78.9 ft-lbs @ 7400 RPM
This equates to a maximum horsepower gain of +5% and a maximum torque gain of +4%!
ELECTROSYNTEC TECHNOLOGY — RELEASES HIDDEN HORSEPOWER!
edit: ir dar dadedu, ka jau visai butu aisku. bezas tauposi! http://www.sae.org/technical/papers/1999-01-3468
Racing Engine Oil
