Username wrote:Taigi ka mes turime:
+2ag (180 vs 182 be ram-airu).
Svoriu nera bet speju bus kaip senas +- 1 kg
Yra tie svoriai
Sorry, kad ipeistinu belekaip
TECHNICAL SPECIFICATION 2009 YZF-R1
ENGINE
Type Liquid-cooled, 4-stroke, forward-inclined parallel
4-cylinder, 4-valves, DOHC
Displacement 998 cc
Bore x stroke 78.0 x 52.2 mm
Compression ratio 12.7:1
Max. Power 133.9 kW (182 PS) @12,500 rpm
Max. Torque 115.5 Nm (11.8 kg-m) @ 10,000 rpm
Lubrication system Wet sump
Fuel supply system Fuel Injection
Clutch type Wet, multiple-disc coil spring
Ignition system TCI
Starter system Electric
Transmission system Constant mesh, 6-speed
Final transmission system Chain drive
Primary reduction ratio 65/43 (1.512)
Secondary reduction ratio 47/17 ( 2.765)
Gear ratio 1st gear 38/15 (2.533)
Gear ratio 2nd gear 33/16 (2.063)
Gear ratio 3rd gear 37/21 (1.762)
Gear ratio 4th gear 35/23 (1.522)
Gear ratio 5th gear 30/22 (1.364)
Gear ratio 6th gear 33/26 (1.269)
CHASSIS
Frame Aluminium Deltabox
Front suspension Telescopic forks, Ø 43 mm
Front wheel travel 120 mm
Rear suspension Swingarm
Rear wheel travel 120 mm
Caster angle 24º
Trail 102 mm
Front brake Dual discs, Ø 310 mm
Rear brake Single disc, Ø 220 mm
Front tyre 120/70 ZR17M/C (58W)
Rear tyre 190/55 ZR17M/C (75W)
DIMENSIONS
Overall length 2,070 mm
Overall width 715 mm
Overall height 1,130 mm
Seat height 835 mm
Wheelbase 1,415 mm
Min. ground clearance 135 mm
Wet weight (including full oil and fuel tank)
206 kg
Fuel capacity 18 litres
Oil capacity 3.73 litres
