Газ-мяс kampelis
Re: Gas Gas Gas kampelis
apsiblioviau....po savaitgalio nusitryne nuo galinio ratlankio uzrasas excel rim
akvareliniais.
Reikes dazu i agrotiekima vaziuoti
Tai ir mano exeliai tik nusitrynė
Kadangi savininkas reviuso nerašo (musiek vis dar bando skaityti ispanišką manualą
), remsimės fuente internacional de informacion
The motor is strong and smooth. It is plenty fast but still has a good trail personality. Handling is very light without being nervous or twitchy. It is easy to ride fast and does not require much of effort to do so. The brakes are very good, nearly on par with the KTM and better than just about everything else. The AJP Juicy clutch is ultra light and smooth. The suspension has come quite a ways from the previous models. The shock works very well. The fork gets better every ride. The stock spring rates should suit most riders. The four position bar mounts let the cockpit riding position open up enough to fit me.
As for the things I don’t like the list is not too long. The rear brake pedal is a huge eyesore. Jordan Brandt has a Hammerhead YZ pedal grafted on his bike, but it took some machine work to accomplish. The stock Rental Twinwall bar is super strong, but way to stiff for me, even with the crossbar removed. The stock GG pipe seems pretty flimsy, it dings easily and mine cracked down the seam.
nu traxai ir revjusas. Cia apie kiekviena gali taip nieko nepasakyt. Esminiai klausimai ar kyla an ratelio, kieik ain ir kiek ryja isvis nepaliesti.
OK, antriniai šaltiniai informuoja, kad varliokų 2005 m. Moto Verte magazinas atliko net 15 baikų shootautą (kaip ir kur testavo nežinom). Rezultatai gavos tokie va įdomūs rezultatai:
1.Gas Gas 250EC
2.Sherco 450i (KTM engine fuel injected)
3.Gas Gas 300EC
4.KTM 450EXC-R
5.KTM 125EXC
6.Beta 400RR (KTM engine again)
7.Honda HM 250 CRE-X (Italian made Honda enduro)
8.Honda HM 250 CRE-R (ditto)
9.Husqvarna 250 TE
10.Husaberg 450 FEE
11.Beta 525 RR (KTM engine)
12.Yamaha 250 WR-F
13.Husqvarna 450 TE
14.Husaberg 550 FEE
15.Yamaha 450 WR-F
(Absence of the TM range and KTM 300)
1.Gas Gas 250EC
3.Gas Gas 300EC
4.KTM 450EXC-R
5.KTM 125EXC
9.Husqvarna 250 TE
10.Husaberg 450 FEE
12.Yamaha 250 WR-F
13.Husqvarna 450 TE
14.Husaberg 550 FEE
15.Yamaha 450 WR-F
Pagal įvertinimus tai traxa turėtų pirmas testuot gazgaza
zil130 wrote:Pagal įvertinimus tai traxa turėtų pirmas testuot gazgaza
heh. prasau neduminti akiu 2005u metu subjektyviais parsidaveliu varliaedziu reviusais.
noretau isgirsti objektyvia patikimo ir rimto zmogaus nuomone. pvz rashydas ir gas gas.
PS remiantis zilo komentarais gasgaso testuoti man niekas neduos, tik prisisnekesiu
