Macna motociklų aprangos
Re: Macna motociklų aprangos
ir pasiaurintos
Na ką, visos mindaugasa problemos išspręstos.
Karšta - imk cooling vest'ą.
Kas nors ką nors esat girdėję apie tokią technologiją (pateikiamas google translate tekstas NL/EN)
http://www.splashdesign.com/epages/Spla ... cts/050691" onclick="window.open(this.href);return false;
Cooling vests not only provide extra comfort during the hot summer days, the risk of heat stress and fatigue is also reduced. And that is as safe. The newest DRY Cooling Vest Macna provides this necessary cooling by evaporation of water. Through the use of a patented technology takes the evaporation of the water available regulated. Unlike conventional cooling vests that similar techniques, it remains DRY Cooling Vest Macna at all times both inside and outside really dry. In addition, the useful life many
times greater than conventional vests by the efficient regulation of the evaporation process.
The DRY Cooling Vest is normally filled with water up to 600 ml. Includes water weighs DRY Cooling Vest never more than 1 kilogram.
Completely filled, the DRY Cooling Vest capacity to one to three days to cool, depending on the ambient temperature where you are driving. Once the vest is
filled immediately starts the cooling effect of the upper body. By cooling of the vascular system increases the risk of heat stress of the body dramatically.
This, combined with the high life, make the DRY Cooling Vest ideal for long rides and touring trips on the bike.
Besides the high life, the DRY Cooling Vest also high durability. The vest is washable and even after many washes keeps DRY Cooling Vest always
cool without getting wet.
tai labadiena,
saldymo efektas gaunamas garinant vandeni?
modeliuoju situacija: karsta, poznane, leksim.
tai kur det vandenine liemene? po kombezu ar ant?
jei po, tai pilant vandeni is bato bus galima susidomejusiems aiskinti: kai jus ateisit 300kmh i posuki, tai is batu ne pilsit, o kratysit
jei - ant kombezo, tai gal nelabai saldys?
sita liemene reikalauja kvepuojancios tekstilines aprangikes.
Taip, čia kogero ne aktyviam sportui. Bet mes aktyviai ri nesportuojam. + girdejau, kad perforacija atlikta maksimaliai, tai kvėpavimo efektas lyg ir turėtu būti...
taip, perforacija valdo
norejau sakyti, kad galima liemene naudoti kakavai persivezti, bet prisiminiau, kad viskas isbegs.
o nera macnoj nekiauru liemeniu?
Yra, bet labai patraukia dėmesį, tad netiks
aš tai skaitau, kad bbstašėj čia su tikia šaldymo liemene, nes kaip gi spalvas prie jos prisiūsi?
kol rashydas i duris nepasibelde dar paklausiu kadangi nesupratau. cia ji reikia vandeniu (spiritu?) uzpilt ar jis isigeria vandens? gal glikolis efektyviau butu? ar galima ziema naudot? o jeigu kaip papildoma benzo baka?
laukiu atsakymu i visus klausimus, aciu.
wundis wrote: cia ji reikia vandeniu (spiritu?) uzpilt ar jis isigeria vandens? gal glikolis efektyviau butu?
Akylesnis skaitytojas pirmoje nuotraukoje turėtu pastebėti nediduką užpylimo čiaulęlį...
bet tai as megstu macna! kaip fetisitui su stazu, tos uzdedamos apykakles, liemesne etc. mane veza
edit: dar pagalvojau, kad jei su saldanciaja liemene pavyktu nusivolioti, tai grazu butu: bala!
tai uzpilus liemene skaitau pries gonke reik dar i kamera imest ir vualia. leds priedo atliks ir apsaugu funkcija.
Visus klientus informuojame apie prekės pritaikymą bei panaudojimą gamintojo frameworke.
Kai paliekate pinigus mūsu kasoje ir laimingas išeinate pro duris - tai jau tik jūsu ir liemenės reikalas, ką veiksite po kaldra
Beje, raidauto į Biržus ir atgal, per lietų ir vos pliusą, pratestuotas Macna Gator švarkelis. Ta proga pasiaukojau ir nesivilkau ant viršaus raingearo. Lietaus pamušalas atidirbo na vse 100, likau sausas. Žinau, kad pirmininkas būtų užsivilkęs ir vėsinančią liemenę ir fortkes visas atsidaręs, bet man tik su termo+t-shito maikėm po apačia, pralėkus kažkiektai kilometrų tapdavo nejuokais vėsoka ir mintyse varčiau katalogus su šildomom liemenėm instead.
Skaitau turint normalias kelnes būtų buve way šilčiau :dokitkelnių:
Uojojojy... goretexas ant vatiufkes, o dar ant virsaus makna. Pasakysiu: mazakraujyste arba skydliauke suletejus. Jokia makna nepades.
Sian ryte +2.5C, kostiumas, kelnes ant kanto , slipsas ir tekstilinis ant virsaus su atidarytom fortkem. No problemos, ciki oras.
mobile mindaugasa
Kertu atgal - gal kenčiate dėl širdies nepakankamumo beigi antsvorio, jei nuolat karšta, net ir esant vėsiam orui? :troll:
Grįžtant prie temos, tai sakot amebinis ride-to-work lygus 2,5 h prie 120-130km/h smaugimu per nipagodą? hehe
