Kickstart fitment
Remove the outer gear and bearing for now so that you have just the splined shaft complete with 'keyhole' ratchet (sledge key) and it's tiny spring fitted. The diagram in the parts manual shows the kickstart spring the wrong way around! So you need the straight pointed end to face away from the bike at your face!
Fit the straight part of the spring into the tiny hole in the kickstart mechanism and then fit the hooked end into the engine case feeding it all in as one. Leave the body of the splined shaft OUTSIDE the crescent and re-fit the kickstart arm at 11 o'clock. Start winding the unit clockwise until the 'keyhole' shaped ratchet piece goes past the 'stop' of the crescent plate. Now, holding the sledge key 'closed', press the unit down into the case using the kickstart lever to 'wobble' it down. Release both the keyhole and the kickstart lever. The unit will turn itself counter-clockwise and rest against the shoulder of the crescent. Now hold the gear down while you remove the kickstart arm and you're ready to fit the bearing and gear on. Because the keyhole is 'closed up', the gear will drop on!
skerdykla numeris 5 uzdaryta
valit!
- Attachments
- jis gyvas.jpg (46.59 KiB) Viewed 1236 times
o kame klausimas?
itempi spyruokle ir uzdedi kika
tadu uzdedi sankaba, dangty ir pompa
otada jau na vese dengi!
Vielen dank. Nors viską taip ir darėm, bet su visu outer gear, todėl pusiau aklai,wundis wrote:Kickstart fitment
kažkaip nedašuto, kad jį galima nuimt, tuomat fakc, kad viską matai ir ...
užkundam ir lakiam.
O problema yra tame, kad vos kaŽkas sujuda - pyst ir nebeveikia, iššoka tas keyhole detalė, turbūt kaltas šitas "dalgis" nu nudrožtu galu (kairėje),
o gal ir ne...
Kazkodel abejoju ar del to nebeveikia. man rodos briedzio irgi nudroztas buvo, bet cia gal del netinkamo spardymo? nors nezinau. davirink!
ne nu šicas kantpelis notomorrow.
Yra ten dalių katros laiko?
Spardyt bergus apart to, kad išvirkščia koja, tai dar ir manieringai reik
Anas siandien vienas bergas atlaike softine pakatuske.Nu + bergui
ajhogi, voverei +1 uz ekskursija
numinta dusimtai kazkiek km. vaziavimo 4 su biskium valandos. einanakum.
Chable - eto dien pobedy!
Dainelė šūdina, savo laiku norėjos duot į siurblį už ją,
bet šiandien tai buvo pirma mintis įveikus tą mechanizmą. Pergalė maža, bet pergalė.
Vienžo, daba galiu nežiūrėdamas ir nenuimdamas sankabos viską padaryt.
Variklius all-in-one, galima būtų ryt uždaryt skerdyklą, jei ne fokin komandirovkė...
p.s. ir YES, problema ne "dalgyje", pati ašis stryktyeli iš vietos, kol nėra prispaudžiančio viso dangtelio uždėta... gal irgi kažkurioj vietoj pasidevėję. Nugi nenaujasble.
tai pirmu reisu pas db i garaza surinkinet ano kiko mechanizmo? masinis tutorialas? storms prisijungia? tckd atves alaus.
O pas mane nusidroze priesingoj pusej tiltelio.. Ir viskas, kaip itariam, nuo motoro vartymoRammst wrote: O problema yra tame, kad vos kaŽkas sujuda - pyst ir nebeveikia, iššoka tas keyhole detalė, turbūt kaltas šitas "dalgis" nu nudrožtu galu (kairėje),
o gal ir ne...
Na anyway.. Ryt baigiu ofisa visa perkraustyt i nauja vieta ir uzsiimsim bergo DArinkimu
kai tik užraukiu kamandirovkę, sudedu viską rėman,
dar surenkam antrą skerdieną (garažiuky dabar gi du),
nu ir galima ant tutorialo, jei DB dar bus naužraukęs.
tik jaučia mano kepenai - peraugs visa tai į litrobolą, ir vėl ate sportui...
Kadrai iš bergistų workshopo:wundis wrote:tai pirmu reisu pas db i garaza surinkinet ano kiko mechanizmo? masinis tutorialas? storms prisijungia? tckd atves alaus.
nutaiva
pasirodo mano bergas be texnikines
reikia ryt praeit
kaip skaitot, sonine kojele/jos nebuvimas gali but tam kliutis?
reikia ryt praeit
