4T 250 MX islaikymo kainos
siaip thumpertalkas ten viskas parasyta, galiu pacituoti:
If its running good, and you get good results on a cmpression test, I wouldn't worry about it. I don't really know anybody that needs a new piston and rings at 25 hours. I don't really know anybody that can use all the power from these bikes either. If you take care of it, keep oil changed, and air filter cleaned, I think it should last you a while. I am just going by what other people tell me. This is my first 450 also, and I am learning as I go.
mate of mine easily got 160 hours out of the piston and rings on his 08, started to loose some compression towards the end but still ran very well, notesably better after the piston and rings though.
unless your a pro level rider i wouldn't evan consider a rebuild until 75 hours.
Kadangi turiu daug laisvo laiko, telikas visada dël fono ájungtas, tai þiûrau visoká briedà. Taip uþmaèiau interviu su Kalmanovièium. Tai jis pasakojo kaip norëjo ásigyt lëktuvà ir klausë kokios sànaudos já iðlaikyt. Jam atsakë - jei taip klausi, tu dar nesi pasiruoðæs jo pirkti.
Perfrazavus, tà patá galima bûtø sakyti ir apie mx, ir apie visus kitus du ratus.
Rashydas pirmas zmogus parases i tema
Labai gera pradzia. Dar butu idomu suzinot apie cilindro galvos daliu keitimo intervala. Velgi, kad bent kazkiek orentuotis ar tai yra 100h ar 1000h ir pan.
Kaip galima kroselka lyginti su lektuvu? Turbut reikia pirma nusipikrti daikta, o tada "o ple, nemaniau kad ta ir ana reik keist kas 3 vazinejimus. Gal einu parduosiu ir vel pasimsiu 2t"
e, mf dar kol kas ne search enginas..
eini i http://www.thumpertalk.com/forum/
pasirenki net savo norimo moco marke ir kali searcha su raktazodziai maintenance, piston, camshaft, topend, bottom end, valves, valve train, rebuild, split cases, cylinder, honing, ir t.t.
Woo wrote:Rashydas pirmas zmogus parases i temaLabai gera pradzia. Dar butu idomu suzinot apie cilindro galvos daliu keitimo intervala. Velgi, kad bent kazkiek orentuotis ar tai yra 100h ar 1000h ir pan.
va tokius atsakymus uzskaitau! skiriu pliusa ir einu sviestis. Kai pasidarysiu isvadas, pasilaikysiu jas sau, nes niekam jos neidomiosRashyd wrote:e, mf dar kol kas ne search enginas..
pasirenki net savo norimo moco marke ir kali searcha su raktazodziai maintenance, piston, camshaft, topend, bottom end, valves, valve train ir t.t.
bet tai ank tiek tamsta esate zanoza v zhope!Woo wrote:Rashydas pirmas zmogus parases i temaLabai gera pradzia. Dar butu idomu suzinot apie cilindro galvos daliu keitimo intervala. Velgi, kad bent kazkiek orentuotis ar tai yra 100h ar 1000h ir pan.
Ogi nugi jei cia nieks nevazioja su tuo dupem tai tau nieko ir nepasakys.
Klausk tu kur vazioja. pvz. TT. Arba kokia miela knyga isigyk ir skaityk shaltais ziemoz. Pvz.:
http://books.google.lt/books?id=hR5vqcv ... q=&f=false
Kazkur apie 154 psl. acakymai i tavo klausimus pasideda.
Arba pirk.
http://www.amazon.com/Motocross-Off-Roa ... 089&sr=1-1
P.S. argi imanoma savo pomegi vertinti ir riboti kazkokiais tai niekingais pinigais? Suformavus teisinga atsakyma atkrenta daug klausimu.
Arba pirk.
siaip dar vienas juokingas aspektas woo vargsta aiskinasi kiek kas kur po kiek bet dar net vaziaves 4t dupiam nera
a) gal visai nepatiks ir net neaptures
b) aptures nevaziaves ir net nesuvaziaves puse stumoklio issiparduos
c) krizepize kokie dar motociklai?! valgykit bulbas ir bukit laimingi!
