demesiui tu kurie neturi daug elektros ant moto
nepykit
Re: demesiui tu kurie neturi daug elektros ant moto
Post by nepykit »
didzhej wrote:cia galimybe papildyti :)
http://www.zupin.de/pdf/katalog2007/262-263.pdf
nicht vershtanden wir deuchlanden language, translaten bitte
nixt tu ferstein. tut kompy!
nepykit
Post by nepykit »
Translaten mit kompy ishtrauka:
Induction measurer SenDEC Top FS 500
Induction measurers for engine hours with 3 auxiliary functions. The tachometer stores the reached maximum permissible engine speed, the "job timer" had a resetable measuring instrument for the engine hours. Been suitable for all 2-Takt and 4-Takt-Motorraeder. Simple assembly. High life span, also when use under hardest conditions. Mass (L xBx H): 65 x45x18 mm
P.S. Vistiek nieko nesuprantu, tikriausiai kokstai neneudingas daigtas :dontknow:
paziurek tautineje literaturoje kas yra motovalandos dvitakciui motorui, paskiau ta pati reiskini stebek ant koviniu keturtakciu.. ir pamirsk, kad yra brYtvos... tada viskas susdes i savo vietas.
nepykit
Post by nepykit »
didzhej wrote:paziurek tautineje literaturoje kas yra motovalandos dvitakciui motorui, paskiau ta pati reiskini stebek ant koviniu keturtakciu.. ir pamirsk, kad yra brYtvos... tada viskas susdes i savo vietas.
o yra brytvos? :-k
tik yzfai ir cbrai...
nepykit
Post by nepykit »
didzhej wrote:tik yzfai ir cbrai...
sako dar ninzdiu buna..
ir samuraju, ir saracenu ir tadu blindu... bet tai neveiksminga!
nepykit wrote:sako dar ninzdiu buna..
Vezliukai Nindzes!
nepykit
Post by nepykit »
Atnaujinu temą. Gal kam bus aktualu.
Gerai žinomas ir daugelio pamėgtas Trail Tech, pagaliau pradėjo gaminti Hour-meterius. Ir gerus! Ir pigius!
Gamintojo info apie hour-meteri su tachometru:
Trail Tech wrote:Works on all gas engines
(including fuel injected four cycle engines)
Tracks total hours on motor, non-resettable
Measures tach up to 20,000 RPM in real time
Remembers max RPM, resettable
Spinning-arrow activity icon
Adjustable display update smoothness (fast/slow)
Adjustable tach pulse sensitivity (high/low)
TTO is the smallest available meter at 50x25x14mm and has large, easy
to read digits. Easily mount it to any surface using either the bolt-on or
peel-n-stick mounting options.
Kainos:
119 Lt (Hour-meteris)
139 Lt (Hour-meteris su tachu)
169 Lt (Temp-meteris oru aušinamiems).
189 Lt (Temp-meteris vandeniu aušinamiems).
dedu pliusa!
hOUrmeteris su tachu - naujas issukis!
nepykit
Post by nepykit »
didzhej wrote:dedu pliusa!
Niekur nerašiau, kad tai naujas išradimas, idėja pirmąkart paminėta dar šumerų dantiraščiuose ;-)
Nauja tai, kad Trail Tech, ir nauja tai, kad gera kaina ;-)
as ne kaip naujiena dziaugiuosi. o kaip atradimu ant lt zemeles.
nusiunciau net kartingistams!
nepykit
Post by nepykit »
didzhej wrote:as ne kaip naujiena dziaugiuosi. o kaip atradimu ant lt zemeles.
O as pagalvojau, kad ce sarkazmas toks ! :)
