Svorio metimas - GSX-R 1000 K2 : 165 Kg :)
Jeigu nesate quecevest, ir norite kad VALINTU, zemiau receptas kaip vienas bicas sukudino GSX-R 1000 K2 iki 165 Kg "slapio" svorio.
Idomu KA tada reiketu padaryti CBR 1000 RR karvutei??? :D
There is a lot of weight in just being obsessive about it.
I've machined stuff down and removed a lot of stuff....
Removed -
Horn
Radiator fan
Half the subframe
Pillion pegs
Tool kit
STV's (Blades, rod, actuator motor, sensor and even the wiring for it)
SET Motor, cables, bracket
PAIR system (including the valves , covers, hoses etc)
Bar ends
Brake Reseviors
Indicators (intergrated into tail light and mirrors)
Lots of brackets and metal tabs
I've replaced almost every bolt on the bike with Titanium or Aluminium and I've machined the new bolts when ever they are longer than they need be.
Bolt on weight loss...
BST Wheels
QB Carbon Fuel Tank
QB Carbon Air box
Race Fairings
Bitubo Rear Shock
K5 Forks woth Bitubo cartridges
Radial Calipers (lighter than the stock 6 pots)
Yoshimura Rearsets
Galfer Rotors
Mini Rear Caliper
Odyssey Battery
Hyperplates
Yoshi Race Alternator
Full exhuast system
CF Front guard
520 Chain, AFAM Sprockets
Alloy Rad Hoses
CF Front Sprocket cover
Hayabusa swingarm (it's actually lighter than the stock one)
K3 Throttle bodies (lighter than K2 ones)
Some of the custom stuff ....
PIAA Headlight (same as Suzuka 8 hr bike)
Front Fairing support (lighter and holds MXL)
Custom Velocity stacks
Custom brake reseviours
Custom CBR tail light
Custom Aluminium Fuel tank hinge
Custom Electric water pump and controler
Custom mini ignition barrel
Custom Panel Filter
I do have some stuff on there that's heavier than stock.....
Yoshimura Clutch Cover
Yoshimura Alternator Cover
Yoshimura ECU
Yoshimura Suspension rocker and links
Yoshimura Adjustable Triple clamps
Yoshimura Clipons
Motty AFR unit
AIM MXL dash
Fuel tank baffle
Radiator guard
Active billet throttle
http://www.gixxer.com/forums/showthread ... 250&page=2
nu ka as galiu pasakyti, nesveikas zmogelis ir tiek.
man labiausiai patiko "Custom CBR tail light" :D
Skaitau jami varikli ir begi pats...
Arvis wrote:Skaitau jami varikli ir begi pats...
:lolol:
tai tas ant to ir gausis! CBR 929 RR variklis sveria ~60 kg. :)
:eek: te viens toliau paskaicius iki 159 nulengvino 01'u !
nepaskaiciau. cia beveik i tema, kad kadais GSX-R 1000 K1 / K2, buvo mano labiausiai norimas motociklas ir tik laiku negauta paskola leme kad neigijau sio modelio. na bet storms sako kad jie sh*^#*0 taip kad ir nesigailesiu!
kad gixeris yra gaidys, pasakys kiekvienas
iseik i gatve, pastabdyk belenkuria carrera, islipes juzefas tau iskart paaiskins
storms wrote:kad gixeris yra gaidys, pasakys kiekvienas
isei i gatve, pastabdyk belenuria carrera, islipes juzefas tau iskart paaiskins
Siandien kaip skaiciau tik apie 2009 Nissan GTR, tai anas surenka 60 mph per 3.3 sek, o quartermile 11.6. Porsche 911 turbo sedi ir verkia!!! Nebent efkunas su brytva apdraguotu Aleksoto aledrome.
Kad nebutu off-topic siulau padiskutuoti kokia jusu manymu geriausia japoniska motociklo marke.
efk0nas
Post by efk0nas »
geriausia ever markė iš visų važiuojančių yra daihatsu =;
