2008 ZX14 Specs
Moderator: Supersport
2008 ZX14 Specs
Specifications
Listed below are the technical specifications for this product. Engine type Liquid-cooled, 4-stroke In-Line Four
Displacement 1,352 cm³
Bore x stroke 84 x 61 mm
Compression ratio 12.0:1
Valve/Induction system DOHC, 16 valves
Maximum power 142 kW {193 PS} / 9,500 rpm
Maximum power with RAM Air 149.5 kW {203 PS} / 9,500 rpm
Maximum torque 154 N·m {15.7 kgf·m} / 7,500 rpm
Fuel system Fuel injection: ų44 mm x 4 (Mikuni)
Ignition Digital
Transmission 6-speed, return
Final Drive Sealed Chain
Primary reduction ratio 1.556 (84/54)
Gear ratios: 1st 2.625 (42/16)
Gear ratios: 2nd 1.947 (37/19)
Gear ratios: 3rd 1.545 (34/22)
Gear ratios: 4th 1.333 (32/24)
Gear ratios: 5th 1.154 (30/26)
Gear ratios: 6th 1.036 (29/28)
Final reduction ratio 2.412 (41/17)
Clutch Wet multi-disc, manual
Frame type Monocoque, aluminium
Rake/Trail 23° / 94 mm
Suspension, front 43 mm inverted fork with top-out springs. 13-way Compression damping. 11-way Rebound damping. Fully adjustable Spring preload.
Suspension, rear Bottom-Link Uni-Trak with gas-charged shock. Stepless Compression damping. Stepless Rebound damping. Fully adjustable Spring preload.
Wheel travel, front 117 mm
Wheel travel, rear 122 mm
Tyre, front 120/70ZR17M/C (58W)
Tyre, rear 190/50ZR17M/C (73W)
Brakes, front Dual semi-floating 310 mm petal discs
Dual radial-mount, opposed 4-piston, 4-pad
Brakes, rear Single 250 mm petal disc
Opposed, twin-piston
Steering angle, left / right 30° / 30°
Dimensions (L x W x H) 2,170 mm x 760 mm x 1,170 mm
Wheelbase 1,460 mm
Ground Clearance 125 mm
Seat height 800 mm
Fuel capacity 22 litres
Dry weight 224 kg
Automatic Headlights On (AHO) n/a
Complies to EU emission limit EURO 3
Ignition Digital
Wheelbase 1,460 mm
Seat height 800 mm
Dry weight 224 kg
Radau pas save biski lietuviskesni taip ir nepanaudota specssheeta jei kam aktualu:
http://nepykit.puslapiai.lt/docs/ZX-14R ... acijos.xls
beigi pakartoju, kadangi visai y tema, linka y zx-6,10 ir 14r broshiura:
http://nepykit.puslapiai.lt/docs/08SuperSport.pdf
ahahah, prikeliu tema:
pavasaris pavasariu, o siandien gveldensiu dar karsta is minciu ir emociju orkaites tema - Z.
kas tas Z galetu paklausti guvus skaitytojas. ar Z cia reiskia zalia kaip agurkas spalva? Taip! O dauguma zino, zalia - kawasiklu spalva. taip, mielas skaitytojau, siandien isgirsi kaip ameba teskena apie visa europa ismaisiusi (ir Lietuva, beje) zzr 1400 2006 gimimo.
diena prasidejo su popietiniais gaidziais, burnoje prisiminiau vakarykscio undergroundo (hehe, aciu miestieciai!) kvapa. gi, sakiau, jei oras geras - jemsiu kawasekla ir darysiu fotoraidautini reviusa prie atlanto. kur buves kur nebuves prasitryniau kukius ir jau buvau prie garazo. pagal plana, viena kawasekla reikejo uzvest nuo kito kawaseklo, lygiai tokio paties, tokios pat spalvos tik balto. bet kaip zinia, planai griuna, ir ilgai keikiausi kuomet pagaliau praskynes kelia iki akumo suzinojau kad turimi "krokodilai" biski truputeli sugede, ir vietoj malonaus ausiai duzgimo girdejau tik savo paties keiksmu aidus ir ta specifini birbima.
antras dublis buvo labiau pavykes, nes prisiminiau kad netoliese stovi didelis dyzelis, o ir laidus spejau paknibinet. visa sita operacija uzsitese ne pagal norus ilgai, nes kaip zinia akumuliatorius pas anuos slepiasi giliai, nepatogiai ir dar balazinokaip, uzsip*sau kariaut su laidais, o yvl'o (atrodo) intymus uzvedimo metodas ne ka gelbejo :/ taigi, susirinkau iranga, paemau pora papildomu aksesuaru ir jau sukau rankena. pries pradedamas nupasakoti emocijas, turiu pasakyti kad kaip motoinventorius pastarasai turetu klasifikuotis kaip-o sports toureris, o bet taciau kone 190 kumeliu po kapotu... atidus skaitytojas zinos, kad iki siol pikciausias testuotas kelio inventorius buvo pries gerus 2 metus maigytas r1, tad visa sita mano rasliava nudieniniam smaugejui gali atrodyti juokingai ir kasdieniskai - bet yra kaip yra.
zodziu, pirma sypsena atsirado vos radus laisvesni kelio ruoza. uber. zveriskai, neitiketinai, apupenai begejasi belekuriuo begiu. jei dabar reiketu isrinkti mylimiausia begi, sakyciau... visi nuo 3io aukstyn. 1/2 ne taip patinka nes nevalingai kilnojasi
kadangi pradejo lyti ir jau temo, suvokiau kad fotika paemiau veltui, ir kad prie matomos juros/vandenyno siandien nenukaksiu, tad prasukau pro namus atiduoti kuprines. o toliau seke minimalistinis 150 km ratelis po kameru kupinus angliskus greitkelius. kas keisciausia, sypsena nedingsta iki dabar, ir jei iki sio momento buvau tikrai nusprendes jemt ugnies audra, dabar nebezinau nieko. I4 rekiantis variklis taip maloniai glosto dusia, o dar ta neitiketina galia. valyt. ilgi, valinantys begiai... sestu begiu tarp inkilu truputi atsuki rankena (a, beje, lyjo, slidu, tamsu, nieko nesimate ir nebejauciau ranku), o prietaisu skydelis jau rodo 260 (issvajotu 300+ taip ir nepasiekiau nes nebuvo kurble
). akivaizdu kad, kaip bergas purve, taip sitas meilus gyvunelis puikiausiai jauciasi ramiai krusindamas tokiais greiciais. beje, nebuvau rankenos atsukes iki galo niekur per visus 150 km (na, trecdalis buvo mieste, bet vistiek) - vien kliutys priekyje ir myzciojimai del inkilu ir slidaus kelio, uz ka gedingai sau dedu minusa ir einu ant gedos stulpo. musiet sekanciam raidautui reikes nusisukt numereli ir smaugt pagal notomorrow koncepcija.
kaip ten bebutu, iki siandien pliusus rinkes hjc salmas "optima linija - pirk pigiau" gauna riebu minusa uz debiliska triuksma, atsirandanti ties 200kmh. minusa gauna ir tekstilines kelnes, nes atsukus rankena jos smunka.
Binaras ne is siandien:
PS didzhej gerb. didzhejui: S2R ruko, o normalaus reviuso parasyti taip ir negaliu nes taip padoriai jis ir neparaidautintas, nes anas iskeliauja taip ir nepakeites siaubingai tiesiai nuvazinetu padangu. galiu pasakyt tik tiek, kad anas irgi valyt. bet kitaip. su dukaciams budingu daug ir bereikalingo triuksmo
taigis, tingiam skaitytojui reziumuoju:
pavadinimas - kawaseklas
darbinis turis - litras + 400\
svoris - kai stovi vietoje - stora karve. kai smaugi - ka?
spalva - violetine, ble
nusmaugta, km - 150
vidutinis greitis - erm.
valyt? - labai
stabdziai - yra
i posukius ateina - su daina
pinpalas prailgeja, cm - 4
zyles - ziuro
ar noreciau tokio - taip
minusai - norisi smagesnio ismetimo
visogero
PS klausimas ekspertui:
kuo sitas zzr'as skiriasi nuo pusmeciu jaunesnio zx? nes mano akimis ziurint - niekuo. tik kawasakiai viena raide sutaupe. parasyk.
nusmaugta, km - 150
valyt? - labai
stabdziai - yra
zyles - ziuro
visogero
- gintaras13
- Ganerio lankytojas
- Vee Crunchy
Aciu uz revju. 14R yra smagus vairuoti matociklietas. Patogus ir smoof as a silk.
Tik as noriu retoriskai paklaust kam valgyti Svalia jei uz ta pacia kaina gali pirkt Zementali. Jimk Hayabusa ir buk verchas.
Labiausiai kas mane nervina kawasulkose (ypatingai 12R ir 14R), tai mandra konctrukcija be ryskaus praktinio benefito. Pvz akumo lokacija. Total koshmar.
Arba kas nors bandet pakeist zvakes ZX12R..
Zmones krapstosi pusantros su kazkokiu special tool, tam kad jas istraukt. As kadangi jo neturejau, tai nuleidau varinkeli..
- Vee Crunchy
