< Dienos citata >
< Dienos citata >
Manau reiktu uzvesti tokia rubrikele.
Sios dienos citata:
"Sweex ten buvo standart R1 su Aprilios Factory pakaba..."
Vee Crunchy
Post by Vee Crunchy »
=D>
Qu'est ce que c'est
Post by Qu'est ce que c'est »
Algirdekas
Dalyvis
Klube: narys
2006-10-23 20:03 21 þinutë ið 22
Nu tai kad ble,mane vakar prie Jacht klubo nukirto,pradejo pist prota,kad 125cc reik visu dokumentu,teisiu ir pns,tai jei ne brolis butu i aikstele nutempe.. :/ taip sunervavo.. reke gal 30min ant manes..
gediminas
Post by gediminas »
Qu'est ce que c'est wrote:Nu tai kad ble,mane vakar prie Jacht klubo nukirto,pradejo pist prota,kad 125cc reik visu dokumentu,teisiu ir pns,tai jei ne brolis butu i aikstele nutempe.. :/ taip sunervavo.. reke gal 30min ant manes..
emotikonas: tas kur dauzo per stala ranka ir nerealiai zvengia
liudna pasidaro kai pagalvoji apie musu Visuomene...
kaiptik norejau ipastint apie nekurias visuomenes. tuopaciu ir citata.
kas tinges skaityt tai esme tokia, kad Sietle bica nubaude uz tai kad savo namu garaze taisosi masina.
>>> Well I guess I need to vent somewhere... I'm a bit outraged!!
>>> I'm in my 3rd year of doing a full restore to my 87' E30, body is on a
>>> dolly- kinda restore. I got a notice on my door the other day from
>>> the Housing Zone Inspector/Code Compliance Division of Seattle. I had
>>> an un-named compliant from a neighbor. Compliant said I had an on
>>> going "autoshop", noise, dust and fumes.
>>> I returned the call and two days later I the inspector come over for a
>>> full inspection. I work on this car in my garage about 20 hours a
>>> week and only between 9-5 during the day- most the time it's between
>>> 11am-5 pm at best and never on the weekends. If the weather is nice I
>>> often keep my garage door open (spring/summer) when working. Sometimes
>>> I don't do work for weeks at a time- sometimes months at a time. I
>>> also did a break job; the timing belt/water pump/oil change on my
>>> other E30 in the driveway two weeks ago- had it up on jacks with the
>>> hood off for about four-five days. I store two sets of jack stands
>>> and two cheap floor jacks and a few blocks of wood in the driveway. I
>>> work on no other cars at my house and I do no engine "revving" or
>>> testing. Some grinding, sanding- yes… but as of date no paint or
>>> fumes to speak of.
>>> Anyway… I'll cut to the meat of the story. I was found to be in
>>> violation and given a "warning" ticket (soon to be mailed to me) and
>>> given two weeks to be in compliance with city code. I'll be
>>> re-inspected in two weeks on Nov. 2nd. The inspector agreed with me
>>> that I was not running a commercial "shop" out of my house and that I
>>> was working only on two cars that I own. And yes she rolled her eyes
>>> (as well as I did) and said that she was only doing her job and
>>> enforcing the housing code as it is written... and no she would not
>>> give out the name of the person who filed the complaint, but I'm sure
>>> I know who it was… he never has liked me. I'v lived in this house for
>>> over ten years.
>>> Check this out, did you know that (in Seattle):
>>> 1) By code- if a car is being worked on (inoperable) in a residential
>>> area it MUST only be kept in an enclosed structure (garage) and the
>>> door must be closed (fully) at all times- or you are in violation of
>>> city code. You can't work on your car in the driveway (inoperable) at
>>> anytime or you are in violation.
>>> 2) By code- the only things that can be stored in front of your house
>>> is "garden tools, potted plants and lawn chairs… period!
>>> So… I asked, If I had "a " set of jack stands in the drive way (not
>>> being used) and have the garage door open even as little as 12-24"
>>> when she comes back to re-inspect in two weeks (if I'm working on a
>>> car or not, but having this car being worked on inside)… would she
>>> really give me a citation / ticket in which I would have to either pay
>>> a fine or go to court and fight (much like a traffic ticket)… she said
>>> yes… AND if I refused to remove the jacks and keep the door fully
>>> closed at all times (other then when entering or exiting the garage) I
>>> would have further legal litigations brought against me for refusing
>>> to comply with city zoning law's.
>>> I will add that I have been using a power sander/grinder… as we all
>>> know can be a bit loud, but for the most part I'm done with most power
>>> tools... at the moment.
>>> My problem now is… I'm days away from doing a full epoxy base
>>> coat/clear coat paint job and the welding of two quarter panels. I'll
>>> need the garage door open 4" to install a temperary custom made vent
>>> on the bottom of the garage door to vent the paint fumes. The garage
>>> will be sealed with filters and converted into a spray booth for 48
>>> hours… this should be interesting. I may have to work under the cover
>>> of darkness...lol
>>> Now the question is… if I can't have jack stands in my driveway,
>>> painting a car in my garage (with door closed but having a vent to the
>>> out doors) must be a real No-No. Anyone here know of a legal issue in
>>> regards to painting a car at home? The paint I'm using is legal to
>>> use in Washington State as far as I know… but now I'm going to be
>>> under a microscope for sure. All I need is about 48-60 hours to pull
>>> this off, but the inspector was at my door the first time within 24
>>> hours of the first complant- she took pictures to documet the vist.
>>> Even if I'm done painting and she shows up... I still will have a
>>> newly painted car sitting there. She did say that after the second
>>> inspection in two weeks this case will be closed (if I'm in
>>> compliance) with no further inspections unless another complant is made.
skaitau kad tai yra ziauru. Tikiuosi pas mus tokie laikai neateis kai nebegalesi net savo garaze nieko dirbt
jei ateis, tai "laikais" vadinti nebus galima... pezdets.
_hey
Post by _hey »
galiu pasakyti, kad yra tokie laikai jau ir cia.
pries gerus 10 metu tevukas bute sugalvojo susimeistraut lentyna po poros vakaru inirtingo darbo prisistate zmogus is savivaldybes, nes gvo skunda is kaimynu del neaiskiu garsu ir siokio tokio triuksmo (dirbo su pjuklu ir drele :) )
Tas pats dabar. Pazistamas truputi dirbantis su darbo sauga, etc, sake gyvenamojoje zonoje gali uzsiimti kuo nori pakol neuzkliuvo kaimynams - pranesh, visos veiklos greit baigsis :(
Dienos klausimas/fraze is bmw forumo:
Priesistore.
Uzsidejau 'aprasyme' BMW F650 Funduro, bo neturiu jokio BMW automobiliaus duotu metu.
Vladimiras
Auto : BMW320i E36 sedan 92m.
BMW F650 Funduro.Kas cia per modelis?
modelis: google!!
dabar skaitau tesini apie tai kaip tas bicas issiaiskino, kas ant jo apmelavo ir kaip jo si karta nebaus. pakeliui dar issiaiskino, kad, pagal istatyma, galima dazyt namie savo masina tik jei turi specialia (oficialiai patikrinta) ventiliacija ir TIK IS BALIONELIO.
viskas butu ok, BET ji tebekankina viena parke - jis realiai planuoja perdazyti ta masina (aisku kazkur atitinkamoj firmoj). beda tokia, kad kazkurio laiko pas jy vel ateis inspektorius patikrinti kaip "itariamasis" reagavo i gauta ispejima ir ar nevysto neleistinos veiklos. ir pamatys ten perdazyta masina!! :) tai chebra jam dabar siulo susimaisyt firmoj analogiskos spalvos dazu i balionely ir numest lyg netycia garaze, tipo biski dazu dar liko.
fygieju. :)
_hey
Post by _hey »
o tai tipo perdazius firma jam saskaitos negali israsyti :-k
xzn! :) turbut taip idomiau!! cia gal esme ir yra - ant kiek chebra uzduchinta..
o tai amerikoj valgo householders asocijacija. tulzingu senuku mafija. pyzdec samadelkinams. berods buvau imetes atveji. ir nieko nepadarysi! uztai gyvenvietes, kurios veikia ta kontora, nekilnojamo turto kainas palaiko aukstesnes.
kaip, a?
mindaugasa wrote:o tai amerikoj valgo householders asocijacija. tulzingu senuku mafija. pyzdec samadelkinams. berods buvau imetes atveji. ir nieko nepadarysi! uztai gyvenvietes, kurios veikia ta kontora, nekilnojamo turto kainas palaiko aukstesnes.
kaip, a?
Jau kaip tamsta mestu is Balsiu tokia organizacija uz ivairaus plauko eksperimentus garazelyje... tai net asaros is dziaugsmo mums visiems varvaliotu!
Gaila Balsiuose Upravdomo nera. Baigtusi DOSAF konstruktoriu burelis mamentom!
