2007 R1 full test on sport rider
- mindaugasa
laba,
sportrider uzsimirse vis siuncia magazinus.
taigis sios dienos numery pilnas naujo R1 testas.
trumpai: turint omeny sterilius, stokojancius drasos pasakyti kazka konkretaus, amerikenus ir ju testus, turime pasakyti, kad....07 R1 yra nelabai.
gal net labai nelabai?
yra pastabu rimtais klausimais: lagas i rankenos pasukima, ta uzpypinanti kova del max arkliu, suvalganti zemus ir viduri, svilinancios koja ir subine triubos ir t.t.
kadangi salia neturejo kitu 07 litru, tai lygino su gerai zinoma paskutine R1.
turiu pasakyti, kad jei reiketu rinktis is situ dvieju, tai gal imciau pries tai buvusia. panasu, kad gerokai draugiskesne kasdieniam varotjimui. ir maziau gliuku.
aciu, gal imesiu skanus.
- Vee Crunchy
Anava ka apie 07 R1 pastebejo Road Racing World magas:
"It doesn't feel like the thing is fully connected as far as the response goes, " said Toye. "It had some kind of goofy lag there. Sometimes when you would come out of a slower turn, maybe mid-rpm, and say you were late-apexing, and instead of rolling on the throttle you gave it a whack, the thing would hesitate."
" If you got it into a corner a gear high and you were in the 6000 rpm range and rolled the throttle on, nothing happened," said Sorbo. "It doesn't bog , like I'm too low in the powerband and turned on the throttle. There's nothing. Completely lame. I would so totally rather have it bog and feel something. It's like being in a car. What's going on?"
Palyginime su 10R ir 1000RR, 07 R1 buvo apsauktas paskutiniu.
- mindaugasa
- Vee Crunchy
- mindaugasa
paskaiciau aptariama (norejau sakyti "mineta" bet susilaikiau) SportRider 2007 R1 apzvalga ir man patiko. patiko. IMHO motociklas labiau focused, forma neuzgozia funkcijos, zodziu daug maziau audibulka negu iki siol. daugybe protingu patobulinimu (beje, susidaro vaizdas, kad Yamaha daug kur siame modelyje pasuko Hondos pramintu keliu.
noreciau.
noreciau.
- mindaugasa
- mindaugasa
- mindaugasa
